16F877 & USART & Interrupt & Recieve Problem
Discussion in 'Embedded Systems and Microcontrollers' started by LuxFerre, Sep 17, 2007.
  1. LuxFerre
    Jul 5, 2007
    5
    Hello..
    Im trying to make a connection between PC and PIC as you get from the topic..
    In Hyperterminal; my pic can send a char. There is no problem. But when receiving any data, my pic doesnt break his silence. And this frustrates me..
    As i search on net (and go into my electronic knowledge), i find that i should make common ground (pin 5). But when i try this; my pic doesnt send any char. (and nor recieves any data / char)When i leave this pin (5) float, it can send char. (dont say my pic is a little ... you get it)(and it cant receive):eek:. I think maybe i have problems in software. But it works well in Proteus / ISIS.
    Any idea will be great help..
    Sincerely..
    P.S. my code:
    #include <htc.h>
    #include <delay.c>
    void hatasil(void){
    unsigned char zed;
    if (OERR) {
    TXEN=0;
    TXEN=1;
    CREN=0;
    CREN=1;
    if (FERR) {
    zed=RCREG;
    TXEN=0;
    char verial(void) {
    hatasil();
    return RCREG;
    void interrupt kesme(void){
    if(RCIF) {
    unsigned char yak;
    RB5=0;
    DelayMs(250);
    DelayMs(250);
    DelayMs(250);
    DelayMs(250);
    RB5=1;
    yak=verial();
    //yak++;
    RCIF=0;
    DelayMs(50);
    TXREG=yak;
    main(void){
    unsigned char alik;
    OPTION=0xFF;
    INTCON=0b11000000; //çevrebirimlerinin kesme modunun aktifleştirilmesi
    PIE1=0b00100000; //USART alış kesmesi aktifleştirilmesi
    //Kesme hazırlama prosedürü
    TRISC=254;
    //USART hazırlama prosedürü
    SPBRG=129; //20 MHz. kristal için 9.6kbaud
    BRGH=1; //yüksek hız baud oranı
    SYNC=0; //asenktron çalışma
    TX9=0; //8 bit çalışma
    RX9=0; //8 bit çalışma
    SPEN=1; //seri port aktifle
    RCIE=1;
    CREN=1; //RX aktifle
    TXEN=0; //reset TX
    TXEN=1; //TX aktif yap
    RCIF=0;
    //PORTB hazırlanması
    TRISB=0;
    PORTB=0;
    alik='b';
    RB5=1;
    while(!TXIF)
    TXEN=0;
    TXEN=1;
    TXREG=alik;
    while(1)
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    Are you using an RS232 transceiver like the MAX232 or MAX202?
  3. LuxFerre
    Jul 5, 2007
    5
    yes im using MAX 232 equivalent HIN232..
    maybe it helps;
    im measuring 0 Volts on Pic's Receieve pin..
    ive changed ihn232 with another but it stands like this.
    im using 5 1uF caps..
    ive tried both shorted RTS CTS - DTR DSR pins and not shorted.. only 2 pins connected ( RD TD )
    it didnt help..
    im using hyperterminal in handshaking none mode..
    im thinking of a problem in software but it works in proteus..
    maybe hardware
    aarghh.. ive not much time.
    (a circuit schematic will be nice but my draws are a mess..)
  4. LuxFerre
    Jul 5, 2007
    5
    Problem solved..
    The Problem is LCD panel.. I forgot it connected as i manipulate PORTB as all high..
    This confused the pic i think...
    thanx for your help..
