A new analogue synthesizer project I am working on has led me into the world of PIC's, and as I have mainly worked in analog, I am finding PIC programming a bit difficult....
Here's what I am trying to do - the synth uses a MIDI to CV converter for translating MIDI signals from keyboards, etc. to analogue voltages for notes, and a trigger output for the envelope generator.
For the MIDI converter circuit, I need to program a PIC16F84A with some already working and tested .asm code I have obtained from the code author/cicruit designer (written for PIC16F84).
I have successfully converted .asm to HEX using MPLAB IDE, and have been programming the chip using a PIC K150 programmer from an eBay seller, but it will not work no matter what configuration settings I set up.
I can no longer contact the program author, so cannot confirm the configuration settings, and have spent many frustrating hours trying to get the PIC programmed - so could I be missing something very basic here?
The PIC circuit is attached.
Any help would be greatly appreciated!
