16F84 and 16F628A
Discussion in 'Embedded Systems and Microcontrollers' started by tracecom, May 17, 2012.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,879
    1,396
    There is a lot of existing code available for the 16F84. Will code written for the 16F84 (and 16F84A) run with no changes on the 16F628A?
    Thanks.
  2. hexreader
    Apr 16, 2011
    250
    82
    Depends how the code is written, but I would imagine that most code will not work.
    There a many differences, most notably a different memory map and different configuration bits.
    At the minimum, I would think that configuration bits would need changes.
    Depending on program complexity and how the program is written, I imagine changes could be somewhere between trivial to significant.
    Have not tried it though, just going by data sheets and very limited experience.
    I would think that low complexity programs might be fairly easy to convert even with low to moderate programming experience.
    tracecom likes this.
