Greetings !! I am having a very funny problem with the port A configuration of a 16F676 micro. Normally I would blame it on finger problems, and that still maybe the case, but when I clrf ansel RA0 still wants to remain as an analog input. How do I know this ... I have a simulator made by Oshon, which I find to be an excellent simulator, and when it executes the code i.e. clrf ansel, bank 1 selected, it shows what I explained above about RA0. Is the simulator correct, I think it is as basically the circuit I have consists of 4 switches connected to RA0, 3, 4, and RC4. Using btfss, all the other switches do as programmed but when I include the code for RA0 it locks up because it still thinks it is an analog input.
Any help would be greatly appreciated ... Below is some of the initialization code:
;****** CODE BEGINS *********************************************************
start:
bsf STATUS,RP0 ;set register bank 1
;next is VERY IMPORTANT for the 16F676 device.
;by default, the inputs are analog inputs on RESET.
;we must make them digital. ( this info I got from an app. note)
CLRF ANSEL ; this is the code that doesn't appear to function
; we make the outputs = 0, inputs = 1
movlw b'00011001' ; port A bit 0 = input opto
; port A bit 1 = Q1 drive output
; port A bit 2 = Q2 drive output
; port A bit 3 = down input switch
; port A bit 4 = up input switch
; port A bit 5 = disp latch output
; port A bit 6 = N/A
; port A bit 7 = N/A
movwf TRISA ;do it!
movlw b'00100000' ; port C bit 0 = A output
; port C bit 1 = B output
; port C bit 2 = C output
; port C bit 3 = D output
; port C bit 4 = Q3 drive output
; port C bit 5 = reset input
; port C bit 6 = N/A
; port C bit 7 = N/A
movwf TRISC ;do it!
bcf STATUS,RP0 ;set register bank 0
bsf LATCH ;set the display driver latch Hi
bcf Q1 ;set Q1 transistor drive lo
bcf Q2 ;set Q2 trisistor driver lo
bcf Q3 ;set Q3 trisistor driver lo
clrf PORTC
CLRF UNITS
CLRF TENS
CLRF HUNS
BSF LATCH
NOP
NOP
NOP
BCF LATCH
clrwdt ;clr WDT PREP PRESCALE ASSIGN
movlw b'11010100' ;setup timer and prescale
movwf OREG ;the timer has been setup to update the display
;every 16 mS this value controls the brightness of the display
bcf INTCON,2 ;CLEAR TRM0 INTERRUPT FLAG
bsf INTCON,7 ;ENABLE GLOBAL INTERRUPTS
bsf INTCON,5 ;ENABLE TMRO INTERRUPT
clrf TMR0 ;START TIMER/COUNTER,CLEAR PRESCALER
WAIT:
BTFSS SWUP ; wait in loop until SWITCH closure is sensed
GOTO UP ; do the up thing
BTFSS SWDOWN
GOTO DOWN ; do the down thing
BTFSS SWRESET
GOTO RESET1 ; reset the counters
BTFSS SWOPTO
GOTO OPTO ; This is where the code locks up
; if I remove this code the other stuff
; works as it should
GOTO WAIT ;Stay here if switchs not closed
Also I have another question ... the code above is used in a 3 digit BCD counter so only the nibble of the counter byte is used for Port C to drive the BCD inputs of a 7 segment display driver MC14511 and the other two
ports to drive a couple of transistors, can I XORWF my nibble with port c so I don't change the state of the driver transistors ?
Anyway thanks in advance for any help ... take care ... Vic
start:
movwf TRISA ;do it!
movwf TRISC ;do it!
clrf PORTC
CLRF UNITS
CLRF TENS
CLRF HUNS
BSF LATCH
NOP
NOP
NOP
BCF LATCH
WAIT:
BTFSS SWDOWN
BTFSS SWRESET
BTFSS SWOPTO
