16f628a mclr pin turn off
Discussion in 'Programmer's Corner' started by Dodgydave, Jul 1, 2012.
  1. Dodgydave
    Thread Starter AAC Fanatic!
    Jun 22, 2012
    5,172
    779
    Hi how do you assign the mclr pin as an input and not as a reset pin,
    i have tried these lines and none of them work>>
    __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTOSC_OSC_NOCLKOUT & _LVP_OFF &_MCLRE_OFF
    __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTOSC_OSC_NOCLKOUT & _LVP_ON &_MCLRE_OFF
    CFG_MCLRE_OFF
    pragma_CFG_MCLRE_OFF
    ..................................:confused::confused:
  2. Dodgydave
    Jun 22, 2012
    5,172
    779
    DONT REPLY , i HAVE FIXED IT
  3. nerdegutta
    Dec 15, 2009
    2,574
    807
    For future references and other searching: How did you fix it, and what did you do?
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Code ( (Unknown Language)):
    1.
    2. _MCLRE_OFF EQU H'3FDF' ; RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD
    So you have done it correct. Do you know that the PICKIT 2 (and 3) take control of this line then the PICKIT is used to power the chip.
  5. Dodgydave
    Jun 22, 2012
    5,172
    779
    i had a duplicate asm file opened at the same time, so iwas editing the wrong file.. I did it with _Mclre_off
