16f628 interrupt on change help
Discussion in 'Embedded Systems and Microcontrollers' started by chrischristian, May 21, 2008.
  1. chrischristian
    Thread Starter Active Member
    Feb 22, 2008
    43
    I'm trying to use IOC (interr. on change) in 628, here is the code which works well on simmulator but not on hardware, what I want to do is that LED # 1 lights continiously as power is switched on and as interrupt occur (RB4 goes HIGH ) LED # 1 gets off and LED # 2 lights on and this remains so untill interrupt is not removed.
    But, what is actually happening is that as interr. occur (RB4 goes high) LED #1 turns off but, LED # 2 doesn't lights up, can't understand whats wrong, please help !
    Code ( (Unknown Language)):
    1.     list p=16f628
    2.         #include<p16f628.inc>
    3.         __CONFIG  _MCLRE_ON & _CP_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
    4.         ERRORLEVEL   -302
    5.         cblock  0x20
    6.             temp
    7.             temp_s
    8.         endc
    9. ;******************************************************************
    10.     org 0x00
    11.     goto main
    12. ;***********************************INTERRUPT LOOP*****************
    13.     org 0X04
    14. inter:
    15.         movwf temp
    16.         swapf STATUS,w
    17.         clrf  STATUS
    18.         movwf   temp_s
    19.         movlw b'10000000'
    20.         movwf PORTA
    21.         btfsc PORTB,0x04
    22.         goto inter
    23.         bcf INTCON,0x00
    24.         swapf temp_s,w
    25.         movwf STATUS
    26.         swapf temp,w
    27.         retfie
    28.
    29. main:
    30.     bsf INTCON,0x07         ;Globel interrupt enable(we are using interr.)
    31.
    32.     bsf INTCON,0x03         ;RB4-RB7 interrupt on change is enabled/ in other words these pins will also work as
    33.                             ;interrupts and interrupt will occur every time any of these pin changes state
    34.                             ; i.e.:HIGH to LOW or LOW to HIGH, we can not set it to be on eather one state change
    35.     bcf INTCON, 0x00        ;Clear RB4-RB7 interrupt flag so, that another interr. can occur.
    36. ;**********************************SET UP THE PORTS *****************
    37.     bsf STATUS,RP0          ;switch to BANK 1
    38.     movlw b'00010001'
    39.     movwf TRISB             ;set RB0 & RB4 as input
    40.     movlw b'00000000'
    41.     movwf TRISA             ;setPORT A all output
    42.     bcf OPTION_REG,0x07     ; enable weak pull ups on port b/ pull ups mean internal resistors
    43.     bsf OPTION_REG,0x06     ;interuupt on rising age/this is by defoult set
    44.     bcf STATUS,RP0          ;back to BANK  0
    45.     movlw 0x07              ;turn comparators off, so HIGH will be simple
    46.                             ; HIGH rather than +5V (compared to supply) so with the LOW
    47.     movwf CMCON
    48.
    49. Loop:
    50.
    51.     movlw b'00000001'
    52.     movwf PORTA             ;set pin 0 of port a HIGH
    53.     goto Loop
    54.     END
  2. chrischristian
    Feb 22, 2008
    43
    Sorry to bother my bread board is damaged the ckt works good on the other one.
