16A @ 4000VA latching relay
Discussion in 'Electronics Resources' started by alphacat, Feb 15, 2010.
  1. alphacat
    Thread Starter Active Member
    Jun 6, 2009
    186
    Hey.
    I'm looking for a single-coil latching relay that is able to switch 16A @ 4000VA loads.
    Could you please refer me to a manufacturer/supplier that provides such relays?
    Thank you.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You could use a single-coil DPDT or DPST N.O. relay to as a latching relay if you're switching from low voltage.
    It would help if you gave more information about your application; what you're planning on energizing the coil with for example.
  3. alphacat
    Jun 6, 2009
    186
    Hello.
    I'm planning to switch home appliances that are operated from either 220V or 110V mains, and can draw up to 16A.
    Currently, I drive a 1W @ 200mA single coil (from two different directions).
  4. retched
    Dec 5, 2009
    5,201
    313
    What are you using to trigger the relays?
  5. alphacat
    Jun 6, 2009
    186
    I'm using an H-bridge to trigger the single coil.
