1602 LCD Row & Col Question, 8051 LCD Demo test in C.
Discussion in 'Embedded Systems and Microcontrollers' started by Ashton, Dec 26, 2014.
  1. Ashton
    Jun 10, 2013
    I'm trying to determine what's wrong with a simple demo C code to display two lines of text on a 1602 LCD display.
    Whatever (Col, Row) I select everything stays on Row 1 or 2. See section 'Display Text'.
    This is the ONLY project I can get to compile/build in Keil successfully without errors. Everything else I have using LCD.h has countless errors, and produces no output files. (strange characters? is STC 8051 dev board examples).
    Code below:
    Code (Text):
    1.
    2. /********************** 8 bit    LCD1602 ***************************************
    3. //Connects
    4. //1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16
    5. //vss vcc vee rs  rw  e   d0  d1  d2  d3   d4   d5   d6   d7   led+ led-
    6. //gnd 5v  gnd p10 p11 p12 p00 p01 p02 p03  p04  p05  p06  p07  5v   gnd
    7. ******************************************************************************/
    8. #include "reg51.h"
    9. sbit LCD_RS=P1^0;
    10. sbit LCD_RW=P1^1;
    11. sbit LCD_E=P1^2;
    12. #define LCD_Data P0
    13. #define Busy    0x80
    14.
    15. /********Êý¾Ý¶¨Òå*************************************************************/
    16. //unsigned char code user_string[] = {"Happy every day"};
    17. //unsigned char code net[] = {"[URL='http://www.taobao.com']www.taobao.com[/URL]"};
    18.
    19. /********º¯ÊýÉùÃ÷*************************************************************/
    20. void WriteDataLCD(unsigned char WDLCD);
    21. void WriteCommandLCD(unsigned char WCLCD,BuysC);
    22. unsigned char ReadDataLCD(void);
    23. unsigned char ReadStatusLCD(void);
    24. void LCDInit(void);
    25. void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
    26. void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
    27. void Delay5Ms(void);
    28. void Delay400Ms(void);
    29.
    30. /*********** Display Text ********************************************************/
    31. void main(void)
    32. {
    33.     Delay400Ms();
    34.     LCDInit();
    35.     Delay5Ms();
    36.     DisplayListChar(1, 0, "Line One");  // was (4, 0, "TaoBaoID"); (Row,Col ??)
    37.     DisplayListChar(1, 1, "Line Two");  // was (4, 1  "Line two"); Both items print on same row ????
    38.     ReadDataLCD();
    39. }
    40.
    41. /***********дÊý¾Ý********************************************************/
    42. void WriteDataLCD(unsigned char WDLCD)
    43. {
    44.     ReadStatusLCD(); //
    45.     LCD_Data = WDLCD;
    46.     LCD_RS = 1;
    47.     LCD_RW = 0;
    48.     LCD_E = 0;         //
    49.     LCD_E = 0;         //
    50.     LCD_E = 1;
    51. }
    52.
    53. /*********** Write LCD ********************************************************/
    54. void WriteCommandLCD(unsigned char WCLCD,BuysC)
    55. {
    56.     if (BuysC) ReadStatusLCD();
    57.     LCD_Data = WCLCD;
    58.     LCD_RS = 0;
    59.     LCD_RW = 0;
    60.     LCD_E = 0;
    61.     LCD_E = 0;
    62.     LCD_E = 1;
    63. }
    64.
    65. /*********** Read LCD ********************************************************/
    66. unsigned char ReadDataLCD(void)
    67. {
    68.     LCD_RS = 1;
    69.     LCD_RW = 1;
    70.     LCD_E = 0;
    71.     LCD_E = 0;
    72.     LCD_E = 1;
    73.     return(LCD_Data);
    74. }
    75.
    76. /*********** Status *******************************************************/
    77. unsigned char ReadStatusLCD(void)
    78. {
    79.     LCD_Data = 0xFF;
    80.     LCD_RS = 0;
    81.     LCD_RW = 1;
    82.     LCD_E = 0;
    83.     LCD_E = 0;
    84.     LCD_E = 1;
    85.     while (LCD_Data & Busy); //¼ì²âæÐźÅ
    86.     return(LCD_Data);
    87. }
    88.
    89. /*********** Initialize LCD ********************************************************/
    90. void LCDInit(void)
    91. {
    92.     LCD_Data = 0;
    93.     WriteCommandLCD(0x38,0);     //
    94.     Delay5Ms();
    95.     WriteCommandLCD(0x38,0);
    96.     Delay5Ms();
    97.     WriteCommandLCD(0x38,0);
    98.     Delay5Ms();
    99.
    100.     WriteCommandLCD(0x38,1);     //
    101.     WriteCommandLCD(0x08,1);     //¹Ø±ÕÏÔʾ
    102.     WriteCommandLCD(0x01,1);     //ÏÔʾÇåÆÁ
    103.     WriteCommandLCD(0x06,1);     //ÏÔʾ¹â±êÒƶ¯ÉèÖÃ
    104.     WriteCommandLCD(0x0C,1);     //ÏÔʾ¿ª¼°¹â±êÉèÖÃ
    105. }
    106.
    107. /***********°´Ö¸¶¨Î»ÖÃÏÔʾһ¸ö×Ö·û*******************************************/
    108. void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
    109. {
    110.     Y &= 0x1;
    111.     X &= 0xF;         //
    112.     if (Y) X |= 0x40;     //
    113.     X |= 0x80;         //
    114.     WriteCommandLCD(X, 0); //
    115.     WriteDataLCD(DData);
    116. }
    117.
    118. /*********** Iterate through each X char of Y row *****************************************/
    119. void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
    120. {
    121.     unsigned char ListLength;
    122.
    123.     ListLength = 0;
    124.     Y &= 0x1;
    125.     X &= 0xF;
    126.     while (DData[ListLength]>=0x20){ //
    127.           if (X <= 0xF){         //
    128.             DisplayOneChar(X, Y, DData[ListLength]);
    129.             ListLength++;
    130.             X++;
    131.         }
    132.       }
    133. }
    134.
    135. /***********¶ÌÑÓʱ********************************************************/
    136. void Delay5Ms(void)
    137. {
    138.     unsigned int TempCyc = 5552;
    139.     while(TempCyc--);
    140. }
    141.
    142. /***********³¤ÑÓʱ********************************************************/
    143. void Delay400Ms(void)
    144. {
    145.     unsigned char TempCycA = 5;
    146.     unsigned int TempCycB;
    147.     while(TempCycA--){
    148.           TempCycB=7269;
    149.           while(TempCycB--);
    150.     }
    151. }
    152.
    Any advice appreciated.
    Please try and be specific on recommended code changes.
    Moderators note: Please use code tags for pieces of code
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Toss your DisplayOneChar() routine and WriteCommandLCD() directly until you understand how the addressing works.
