16-bit Microprocessor
Discussion in 'Embedded Systems and Microcontrollers' started by kongway, Dec 7, 2007.
  1. kongway
    Apr 12, 2007
    12
    At the attached circuit, did any one can teach me the application and function about it.
    I just know the function of each component, but didn't know the circuit function and it application.
    Many thanks....
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Really fancy parallel to serial converter
    It's taking a ton of I/O and cramming it into one data stream.
    I think.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Whatever it is it strains credulity for you to call it a 16-bit Microprocessor.
  4. kongway
    Apr 12, 2007
    12
    Actually, the circuit title called it CPU1, but i think that isn't the same as CPU.
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Fat chance they will cough up an explanation. Pigs may grow wings first.
  7. RiJoRI
    Aug 15, 2007
    536
    26
    In my schooling we built the baby brother of this: a 4-bit microcontroller that did some very simple stuff (the clock was a debounced pushbutton switch!) so it looks kinda familiar...
    First make the whole thing a black box. You have 16 bits of data in (din), a clock line, a reset line, 16 bits of address out, 16 bits of data out, and a read line.
    Internally, there are decoders for operational control, decoding logic (the and & or gates), an ALU (ADD16/alu) feeding into and being fed by an accumulator (REG16/ac), an instruction register (REG16/ir), an address register (REG16/ad), a program counter (REG16/pc) and a data register (REG16/dr). (Sounds like a 16-bit micro processor!) The multiplexer (MUX8/busmux) controls what data appears on the data out lines.
    --Rich
