16/40 va transformers blowing
Discussion in 'General Electronics Chat' started by J Newburgh, Mar 12, 2006.
  1. J Newburgh
    Mar 12, 2006
    Two 16/40 va transformers burned out on the same alarm panel circuit in the same installation, days apart. New and different system installed resulted in a third 16/40 transformer producing a noticeable hum. New system did not produce the hum when later connected to power in a different home. Any ideas??
  2. pebe
    Oct 11, 2004
    628
    What is '16/40'? Did you check the incomong mains supply voltage?
  3. J Newburgh
    Mar 12, 2006
    16/40 va is a 16 volt ac step down transformer supplying 40 volt amps of power, used mainly in intruison alarm system which operate on 12 volts, converted in the alarm panel to dc voltage.
    I'll check the house power next time on site
    thanks
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Crook back up battery, requiring excessive charging..... crook 13.8 volt regulator..... excessive current draw of the panel electronics.... excessive draw of a sensor.... excessive draw on other accessory....ie outside sounder, autodialler etc etc.
    The only way to tell is to check each. Measure the voltage on the battery.... should be 13.8.
    Remove the main DC fuse and battery. Put a few amps load across the battery and check the voltage doesn't drop below 12 volts.
    Hook a current meter in the fuses place and check current draw. If more than a couple of amps, then disconnect sensors, aux devices etc until you find the culprit.
