16*2 LCD pins
Discussion in 'General Electronics Chat' started by Dritech, May 11, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I think to be on safe side. It is better that you use google and find the exact datasheet for your device
  3. atferrari
    Jan 6, 2004
    2,666
    784
    If your datasheet mentions A & K, those are the terminals of the LED in charge of backlighting.
    Just to be sure: take one datasheet from a LCD with and another without backlight. Compare them.
    In several displays you will find the last two numbers NOT in physical sequence with the rest. Maybe added later to an existing design?
  4. ErnieM
    Apr 24, 2011
    7,437
    1,626
    Your google hit matches the LCD's I have on hand. Those follow that common pattern.
    I would guess 16 pins mean you have a backlight. You should be able to see it, there's a LED or two on one end.
  5. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies. The second link was the correct one, with the first 2 pins being the supply pins. But I have another problem. The characters are not showing on the 2nd line. When I set the potentiometer to full contrast, the squares does not show on the second line either.
    What can cause this problem please? is the LCD damaged?
  6. t06afre
    May 11, 2009
    5,939
    1,222
    The second line starts at adress 0x40h even for 2x16 displays I think
  7. MrChips
    Oct 2, 2009
    12,636
    3,454
    Send at least 80 characters to the LCD and see what happens.
  8. hexreader
    Apr 16, 2011
    250
    82
    This is normal for an LCD display that has not been initialised. There is nothing wrong with your LCD.
  9. Dritech
    Sep 21, 2011
    756
    5
    I am writing 0X80 for the first line and 0XC0 for the second line. This worked perfectly on a simulator.
    I tried that and only the first row is showing.
  10. MrChips
    Oct 2, 2009
    12,636
    3,454
    Forget the simulator. The real world is your testing ground.
    Sending 0x80 and 0xC0 to the instruction register is the correct method for direct character positioning.
    Try sending a continuous stream of characters at a slow rate (2 chars per second) and see what happens. Characters should wrap around after 80 characters.
  11. atferrari
    Jan 6, 2004
    2,666
    784
    Is RTFM an option?
    All I can remember showed the starting address.
    ErnieM likes this.
  12. ErnieM
    Apr 24, 2011
    7,437
    1,626
    As long as failure is still an option it is not necessary to RTFM.
  13. Brownout
    Jan 10, 2012
    2,375
    998
    What is RTFM?
  14. t06afre
    May 11, 2009
    5,939
    1,222
    Read The <snip a F word> Manual
  15. Brownout
    Jan 10, 2012
    2,375
    998
    Welll, I read the manual, but didn't find it. :)
  16. Brownout
    Jan 10, 2012
    2,375
    998
    My apologies to t06afre for my (now changed) response. I totally misunderstood his post.
