Hi friends,
We are working on a project for developing a HIGH VOLTAGE POWER SUPPLY,
Around 15 Kv for co2 Laser.
At present we have power supply using 1N4007 with Vrrm (Peak
inverse voltage of 1000 V).We are using 80 Diodes in series in a diode bank,
To get an output of 15Kv.
Now we want to use diode of Piv or Vrrm= 15Kv (Diode no. HV05-15).
So please tell me what are the values of Ceramic capacitors and Resistances.
Also tell us the formulas for these calculations.
DATASHEET OF DIODE
Part name= HV05-15
Vrrm or PIV 15 kv
Vrms 10.5 Kv
Vdc 15 Kv
If(av) 550 mA
Repetitive Peak Reverse Surge Current...IRSM 100 mA
Non-Repetitive Peak Forward Surge Current...IFSM 200 A
DATASHEET
HV05-15
Maximum Ratings
Value
Units
Peak Repetitive Reverse Voltage -VRRM
RMS Reverse Voltage -VR(rms)
DC Blocking Voltage -VDC
Average Forward Rectified Current -IF(av)
Peak Forward Surge Current(Non Rep) -IFSM
Peak Reverse Surge Current -IRSM
Operating & Storage Temperature Range
Maximum Forward Voltage -VF
Maximum DC Reverse Current -IR
15000
10500
15000
550
200
100
-40to130
15
5.0
V
V
V
mA
A
mA
°C
V
mA
thank you
!DSeva
DATASHEET OF DIODE
Part name= HV05-15
Vrrm or PIV 15 kv
Vrms 10.5 Kv
Vdc 15 Kv
If(av) 550 mA
DATASHEET
HV05-15
Maximum Ratings
Value
Units
15000
10500
15000
550
200
100
-40to130
15
5.0
V
V
V
mA
A
mA
°C
V
mA
thank you
!DSeva
