I have to make a testing installation that, on short, will output a current [A] vs. rotational speed [RMP] graph for automotive alternators.
In order to do that I need a shunt regulator that keeps the voltage between alternator terminals at a lower value than that stabilized by the alternator voltage regulator. In this way I can avoid the influence of the alternator voltage regulator.
So I designed my shunt regulator to avoid the voltage of the alternator to increase above ~13 Volts and to withstand up to 150 [A]. In the attachment you have the schematic I used for the shunt regulator.
Now the problem is that the schematic works fine until 5-6 A. Beyond 5-6 amps the oscilloscope show me some "holes" in which the voltage drops to 5-6 volts. If I try to further increase the voltage across the shunt regulator, the oscilloscope show me that the voltage settles to 5-6 V.
If you have any suggestions about how I can make the shunt regulator work fine at high currents please do not hesitate to advise me.
