1500 watt inverter questions
Discussion in 'General Electronics Chat' started by ShockBoy, Feb 2, 2011.
  1. ShockBoy
    Thread Starter Active Member
    Oct 27, 2009
    186
    I've recently purchased a 1500 watt inverter that seems to be having some issues that I can't explain. I don't want to send it back for an exchange if something else is the issue.
    First the model is Cobra CPI 1575.
    When I first turn it on, the two fans in the back whir up then it beeps flashing "OLP" (overload protection), then it does what it's supposed to do; flash the battery voltage then the watt output.
    Next I grab my volt meter and check the AC output voltage through the plugs in the front and it reads 98.0 Volts. It's not even close to 120 Volts.
    Could that be I need heavier gauge wire from the battery to the inverter?
    Could it be I'm only running one battery?
    One other thing is when I plug lower power items into it, the output shows zero watts, but plugging in an old fan, it shows the watt usage?
    I am quite confused at why it's doing what it's doing.. Any advice would be appreciated. (before I pay to ship it back for an exchange)
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    What is the battery voltage it is showing?
  3. ShockBoy
    Oct 27, 2009
    186
    13.4 Volts. It's on float charge
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    It's designed to be on a running car or truck battery while the engine is running, at 1500W that's about 120A from a 12V source your car battery will boil. You need very short and very heavy gauge wire to boot.
  5. ShockBoy
    Oct 27, 2009
    186
    4 gauge at about 2 foot long is what I was thinking.
    So I should check it on my truck before I send it back?
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
  7. ShockBoy
    Oct 27, 2009
    186
    13.4 is with no load. It leveled off at 12.1 Volts with load, but the low volt output of the inverter made the fan buzz a bit.
  8. marshallf3
    Jul 26, 2010
    2,358
    201
    What kind of load are you presenting it? If totally inductive that could be part of the problem.
  9. ShockBoy
    Oct 27, 2009
    186
    It's an old desktop fan from the 60's. Smaller loads such as charging a cell phone show no watt usage at all.
  10. marshallf3
    Jul 26, 2010
    2,358
    201
    Totally inductive and probably rather inefficient load.
    Have you tried putting a few light bulbs on it?
  11. ShockBoy
    Oct 27, 2009
    186
    no, but I will try that.
  12. marshallf3
    Jul 26, 2010
    2,358
    201
    Well, let's see what it does. If you've got good wiring and a good battery it should be able to run a couple of 250W heat lamps.
  13. ShockBoy
    Oct 27, 2009
    186
    I just tried a 75 watt black light bulb and got a current overload protection error and a low voltage protection error. Bulb was warm to the touch. The battery at 12.6 volts at the start of the experiment. During the experiment the voltage dropped down to 11 volts and the black light blinked every 5 seconds or so. Changed the bulb to a compact fluorescent bulb gave me no error, bulb lit up and inverter watt display read 000 watts...???
    It's got to be my battery/cable thickness...
  14. ShockBoy
    Oct 27, 2009
    186
  15. marshallf3
    Jul 26, 2010
    2,358
    201
    Yea, I think you got a bad one or it was poorly designed to begin with.
    Believe it or not Harbor Freight has some decent inverters as does NewEgg.
  16. ShockBoy
    Oct 27, 2009
    186
    Great.
    Thank you for the help.
