15 minute timer latching
Planetping
Joined Feb 1, 2016
Hi!
I need to build a timer circuit that allows a powered microphone to go live for 15 minutes when a momentary switch is pushed. An led indicator is also required to light for the 15 minute duration.
I am thinking a 555 monostable design connnected to the positive side of the mic/led power. Tried a few configurations but could do with a working prototype ASAP!!
Thanks in advance
PP
ronv
Joined Nov 12, 2008
3,770
Hi!
Thanks in advance
PP
What voltage goes to the microphone?
AnalogKid
Joined Aug 1, 2013
11,056
Lotsa timer modules on ebay, some with digital setpoints and a display. What is the microphone current draw at 12 V? Also, do you really need to switch power to the mic, or just enable/disable its output?
ak
Planetping
Joined Feb 1, 2016
switching the output is and option as long as an indicator led can also be switched. Looking like I may need 100's of these so the easier to make the better!
Dodgydave
Joined Jun 22, 2012
11,307
Switching the output is easy, mosfet or relay, you haven't said which timer you're using, if its for mass production then a pic or other tiny microcontroller is best, forget the 555 timer its useless.
AnalogKid
Joined Aug 1, 2013
11,056
IF the OP has a PIC programmer
AND IF he is fluent in PIC assembler OR PIC Basic OR C++
THEN the cost of clean regulated power for the PIC still has to be figured into the budget.
While this application might be beyond the reach of a 555, there are other timer solutions. I think a dedicated 4060 + 4093 design could compete even without the PIC's programming overhead.
Here is the original form:
I suppose it is tempting, if the only tool you have is a hammer, to treat everything as if it were a nail.
- Abraham Maslow, The Psychology of Science: A Reconnaissance (1966), Ch. 2, p. 15.
ak
