15 - 20 kHz Traingle Wave Generator
Discussion in 'The Projects Forum' started by Farrukh12, Mar 27, 2013.
  1. Farrukh12
    Mar 27, 2013
    6
    How can I generate a 15 - 20 kHz triangle wave using op-amps.
  2. t06afre
    May 11, 2009
    5,939
    1,222
  3. Farrukh12
    Mar 27, 2013
    6
    which op-amp should I use would the 741 be able to witstand 20 kHz wave.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Ouch! If you can, avoid any use of the 741. I really hope you have other options
  5. patricktoday
    Member
    Feb 12, 2013
    157
    42
    A major factor in an op amp for generating triangle waves is the slew rate. That's the speed at which the output can rise in voltage and is measured in V/uS. The 741 will probably not keep up at 20kHz. It does about 0.5V/uS. The LM318 is < $1 and does 50V/uS. There are many others.
  6. Dodgydave
    Jun 22, 2012
    5,170
    777
  7. Farrukh12
    Mar 27, 2013
    6
    I made the circuit in Proteus but it gives no output I also tried different values of R2 and C1 but still no output.
  8. crutschow
    Mar 14, 2008
    13,523
    3,391
    What power are you applying to the circuit?
  9. Farrukh12
    Mar 27, 2013
    6
    I am applying 12V
  10. rogs
    Aug 28, 2009
    279
    37
    Try making R3 100K and R1 470K
