14VDC to 12VDC? flickering light bar
Status
Not open for further replies.
na96ek
Joined Dec 19, 2014
Long story short I bought a used Baja Designs LED light bar for my truck, and after wiring everything up I am left with an issue. When the truck is not running and the voltage is around 12.8V the light operates perfectly.. When I start the truck and the voltage goes up around 14.2V it flickers. When I run the truck and turn on the A/C, radio, headlights, hazard lights etc and get the voltage down to around 13.3V the light is again fine.. What I am seeing essentially is that the light does not like much over 13V... Which is weird to me and I have consulted with Baja designs on this today but the gentleman I spoke with was not educated enough to help me resolve this issue and told me he would be having their "head engineer" consult with me sometime next week, but with the holidays approaching I'm figuring it may be awhile so I'm taking matters into my own hands for now.
What options do I have for limiting the voltage on the light wiring to 12-13V... I have searched around and couldn't come up with anything solid. It needs to be able to pass 15A safely (that's what the fuse is rated for) so some of the cheap voltage regulators I looked at were only capable of doing 6 or 8A
any insight on the matter is appreciated, or if you have any other ideas or suggestions I'm very open to them, thanks!
Wendy
Joined Mar 24, 2008
23,421
The owners of All About Circuits has elected not to host discussions of automotive electrical system modifications/enhancements due to safety concerns, the potential of legal ramifications and the possible circumvention of vehicle regulations at the state and federal level.
This thread is against the AAC forum rules, Chapter 6, as seen here:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This can be found in our Terms of Service (ToS)
Automotive modifications of any kind are strictly forbidden. Therefore, this thread will be closed.
Please try to understand the reasons behind this action, and feel free to browse and use the forums.
You might find answers to your questions in one of these forums:
http://forum.allaboutcircuits.com/showthread.php?t=54400
Another good forum that shares many of the same membership is http://www.electro-tech-online.com/ . Good luck.
Status
