13.56MHz RFID Evaluation/starter kit, with R/W ISO15693 vicinity tags
Discussion in 'General Electronics Chat' started by Pineapplex, Jun 20, 2012.
  1. Pineapplex
    Jun 20, 2012
    Hi, i am looking for a simple easy to use 13.56MHz HF RFID evaluation/starter kit, that comes with ISO15693 vicinity tags that is able to R/W.
    The smaller the size the better, with range of anywhere from 1 to 10 cm is fine. The tags must also have enough memory to store basic info such as name, date, address, etc.
    I have looked through many companies (Texas Instruments, Atmel, Melexis, NXP, SONMICRO etc.), but was only able to find 1 source that matches the criteria. (Here is the link: http://www.ti.com/tool/trf7960aevm)
    I was hoping to find a few other sites or companies to compare with before I make the purchase. Any help is much appreciated.
    Thanks!!
  2. sbixby
    May 8, 2010
    57
    10
    OK, this site is a hobby-level store and everything else you mentioned is industrial-level, but.... I was browsing adafruit.com last night looking again at the unit she makes/sells - it's her own breakout board, but the price is nice and it might be worth checking out. I didn't find mention of the ISO15693-compliant tags you mention, though, but she offers an assortment of "MiFare" tags of which some might serve.
    https://www.adafruit.com/products/789
    Other than that, I don't have anything, and it shows my knowledge is firmly located at the hobby level. :)
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    You might look at the ProxMark 3 (or whatever is the latest version). I'm pretty sure it is compatible with 13.56MHz tags.
