13 -50V to 10V, conversion
Discussion in 'The Projects Forum' started by varunme, Sep 16, 2015.
  1. varunme
    Sep 29, 2011
    59
    what is the easiest and cheapest method for 13 -50V to 10V, conversion
    DC voltage from SMPS
  2. blocco a spirale
    Jun 18, 2008
    1,459
    369
    At what current?
  3. varunme
    Sep 29, 2011
    59
    below 100mA
  4. blocco a spirale
    Jun 18, 2008
    1,459
    369
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    With a 20 V zener it will not operate at 13 V in.
    ak
    #12 likes this.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You could have a look at the LM317HV.
    This may have an input voltage of 60 Volts.
    If you want to go higher, look at the TL783.
    This may have an input voltage upto 125 Volts.
    See the datasheets for more info.
    Bertus
    varunme and #12 like this.
  7. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Good point, I conveniently ignored the lower voltage limit:(
    #12 likes this.
