Who told you that? Battery voltage tends to be very stable within the relatively narrow charged-discharged range....i have been told that it requires a stable voltage from the battery
Last time I checked - an immersion heater was a spiral of resistance wire packed into a copper tube.sorry i do mean immersion i bought 12v immersion on ebay that works dict but needs a clean supply
thanks
For maximum battery life; there should be a UVLO circuit to drop the load at certainly no lower than 10.8V - I've seen stickers on car batteries; "charging not to exceed 14.4V".What do you expect the maximum voltage to be when fully charging?
Max.
IIRC; "off grid" is a useful keyword.@gopher45,Some large wind turbines use immersion type heaters to bleed off current after the batteries are fully charged. Is this what you are talking about? If so it is part of a "charge control circuit". Maybe Google can give some ideas, there's a lot of information out there, if you use the right terms when searching.
