I have to wire a winch so that it is automatic. The winch is 110vac and has a wire for the up and a wire for the down....What I need to do is hook up two switch panels. In each panel there will be a Up and a Down buttons so that the winch will go each way.....Then I will also hook up a limit switch on both ends so the winch will stop where needed. I was thinking of changing over the power so the Panels and Limit Switches are working on 12vdc so it would be a little safer than running 110vac to the switches....I can use relays if I can find something that goes from 12vdc to 110vac. If you guys can help me with the wiring that would be great...also any ideals would help too.
The winch is HERE
http://www.northerntool.com/shop/tools/product_200307347_200307347
Thanks,
Trell
The winch is HERE
Thanks,
Trell
