bwilliams60
- Joined Nov 18, 2012
- 1,442
Just FYI on power window motors. Most systems have used two wire motors until recently and all of these motors do not have limit switches. The limit is set by the window travel and is stopped at the top by the window regulator and body and at the bottom by the window regulator. If you were to hold the button long enough, the motor would overheat and an internal circuit breaker would cut off the power supply. That is the safety mechanism. No limit switches, just motors and breakers. Simple
