I'm working on a 12vdc project that is using a CD tray motor to open and close a small door. I would like to use it with a 4 channel 12v remote control switch so that I can open and close it by remote.
The way I have it wired now I need to hit the on button to open it and once it has fully opened I need to hit the off button for that channel to stop the motor from burning out. I have a separate channel dedicated to closing the door with the polarities reversed. It also must be shut off once it is closed.
I would like to be able to open and close the door from one channel without having to shut off the power once the door has reached either limit. I would settle for using 2 channels like I have now, but is there a way to have the power killed automatically once the door has reached it's fully opened or closed position?
I have been reading about capacitors. Am I headed in the right direction?
