12vdc isolation
Discussion in 'General Electronics Chat' started by guyblom, Jun 7, 2015.
  1. guyblom
    Jun 7, 2015
    Hi All, it's been a while since I dabbled in electronics so I'm hoping for some advice. I have a 12vdc supply and I wish to create two 12vdc signals isolated from each other (from the one source). What is the easiest way to do this? Power isolator?
  2. blocco a spirale
    Jun 18, 2008
    1,461
    370
  3. guyblom
    Jun 7, 2015
    Thank you for your assistance!
  4. DickCappels
    Aug 21, 2008
    2,772
    669
    Use a transformer with dual secondaries.
  5. blocco a spirale
    Jun 18, 2008
    1,461
    370
    For DC?
    DickCappels likes this.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think you might want to clarify what you are trying to do. Your statements so far lead in at least three directions. Rather than guessing which of several directions you are going in why don't you provide additional information. What kind of signals are they for starters?
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    If you can find some old PC EISA Ethernet cards, they used to have DC-DC converters on them - those won't do exactly what you want, but you can identify some brand names and go looking for manufacturers websites.
    I think the Ethernet ones were +/- 9V out from single 5V in, but most manufacturers do a complete range all the way up to 48V telecom stuff.
  8. guyblom
    Jun 7, 2015
    My apologies for being vague, I was unsure how much information to offer. I wish to run 2 lines (channels) of LED's each of which will be dimmed separately. I understand I would need two power sources isolated from each other but I only wish to use one supply/driver. This is obviously possible as many manufacturers do up to 4 separate channels from one power source.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    Why do they need to be isolated from each other? I think the issue might be in your understanding of what electrical isolation means.
    Consider your car electrical system. You have 12V headlights and you have 12V brake lights that are turned on and off separately. Would you consider these two 12V lights to be "isolated" in the same way that you are looking for here?
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I suggest you review the material on series and parallel DC circuits. This will provide a framework for understanding how two separate branches of a circuit can be controlled.
  11. guyblom
    Jun 7, 2015
    I guess I foolishly listened to some "backyard" advice which suggested I needed isolated p/supply lines. Thank you to all who contributed - I shall go and research a little harder and return when I have more informed questions if that's ok.
  12. AnalogKid
    Aug 1, 2013
    4,694
    1,297
    Dimming two LED strings independently does imply some kind of power isolation between them so they don't interact, but full isolation is not required for the task the way you have described it so far. From the 12 V source, two independent switching or linear regulators will do what you want. What is the peak current in each string at full brightness?
    ak
