12VDC Amp Question
Discussion in 'General Electronics Chat' started by mkieff, Oct 4, 2007.
  1. mkieff
    Oct 4, 2007
    I have a solar panel that has the following output:
    1.26W 18V and 60mA
    I want to hook a 12V DC Fan that is rated at .60A. Is there anyway to do this?
  2. techroomt
    May 19, 2004
    198
    you can regulate the voltage down to the 12vdc alright, but you're not going to get the needed 6/10 amp from that .06 amp source, that i know of anyway without some auxiliary power.
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    You will need 10 of those panels connected in paralel.
  4. niftydog
    Jun 13, 2007
    95
    18V @ 60mA is only 1.08W, so those numbers don't gel.
    12V @ 600mA is 7.2W, so there's just not enough power to run it properly. But 600mA sounds like a lot, is it a powerful fan?
