12Vdc 2a Transformerless Power Supply
Discussion in 'General Electronics Chat' started by aq_rules, May 24, 2010.
Thread Status:
Not open for further replies.
  1. aq_rules
    Oct 28, 2009
    168
    I searched this 12VDC 2a transformerless power supply,but i was unable to find it...
    i found 12vdc 20a supply..
    plz post a schematic if possible for 12v 2a supply...
  2. kkazem
    Jul 23, 2009
    160
    27
    I'd be glad to help you, but your specs are too vague for me to answer you. Here is some basic information I would need to help you:
    --Input Voltage level and whether AC or DC.
    --Available input current
    --Maximum allowable ripple
    --Maximum allowable line and load regulation
    I think you are looking for a DC-DC converter, but I need you to confirm that information before I spend my time helping you. Also, tell me what the power supply load is (what will it be powering?).
    When you reply with that, I'll answer you with details.
    Regards,
    Kamran Kazem
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you are talking about trying to make a power supply connected to power mains without a transformer, well, I expect this thread to be closed shortly. There is no safe way to make a power supply without using a transformer.
    Personally I recommend a wall wart.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A DC - DC converter is one thing; a transformerless supply operated from the mains is another. Can the OP clarify?
  5. aq_rules
    Oct 28, 2009
    168
    yea....it will be connected to 220VAc Mains...
  6. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    A powersupply without a transformer WILL NOT BE SAFE.
    The use of a transformer is a MUST.
    There are circuits as SMPS that are small, but still use a transformer.
    Bertus
Thread Status:
