Hi every one, i am a new user of this forum.
I have a problem with my inverter that i use for transform the battery energy to alternative voltage for my house.
I have an fotovoltaic plant and it is my passion.
On the board of this inverter there are 2 KA7500B (one for first stage dc-dc and one for second stage dc-ac).
There are 16 mosfets (8 IRF3205 and 8 SW740) and one LM324 also.
As first thing i found three final mosfets (SW740) in short circuit and i replaced them with others good.
Before of this operation i didn't the voltage after the transformer, while now i have 450vdc after the rectifier bridge, but still i haven't the Ac output voltage.
The capacitors after the bridge are 3x47μF 400v.
Why the voltage is so higher?
it should be about 310 vdc?
I checked the npn transistors drivers of second stage (2 x ksp44) and them are ok.
On web i found an schematic similar to my circuit, but not perfectly same.
Can you give me some suggetions for solve the trouble?
Thank you so much everyone
Kyu9971
Kyu9971
