12V to 5V TTL conversion?
Discussion in 'General Electronics Chat' started by a_tharwat, Aug 4, 2006.
  1. a_tharwat
    Aug 4, 2006
    hi there, this is my first post here.
    I am trying to figure a way to use analog to digital converter IC (adc0808) with an input signal that is not TTL compatible. The datasheet shows that the input signal must be TTL while my signal is 12V.
    Can anyone think of an accurate way of conversion? Thanks alot in advance.
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The only thing that comes to mind is a line receiver such as a 26LS32. They come four to a package, you can set the threshold, and the outputs can be tri-stated.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  4. nomurphy
    Aug 8, 2005
    567
    12
    An op amp with a gain of ~0.416.
