I've got a Harddrive which I want to power from the wall outlet and plug into the PC via e-SATA.
On the harddisk there are these ratings:
Now since the load is 0,7A we know that there will be the same amount over R1 which means the resistor would have to be 10 ohms right?
I know it's better to do with a voltage regulator, but I don't have one and I just happen to have an 11 ohm resistor lying around.
Could the HDD still work with 4,3 volts?
