I have a valve bank of seven valves that needs replacement.
I've found a suitable replacement, however it runs on 24v instead of 12v.
The valves are non latching and draw 31.25 ma of current each.
I need to design a circuit that allows the 12v signals to control the new 24v valves.
I am hoping for an IC based solution. I do not need a circuit built from bjts.
I only need to build this once, so making it low cost isn't really a requirement.
Simplicity is best. Any thoughts on what IC or ICs I should use?
