Hello all,
I have a 1991 Nissan 240SX which I am attempting to retrofit heated mirrors onto.
I am using an OEM switch that functions properly for everything except the heated mirrors.
When the switch is up and the indicator light is OFF, the output wire from the switch to the mirrors gives 12V. When the switch is turned ON and the indicator light turns red, the output wire drops to 0V. I have tried multiple different switches to make sure it wasn't a problem with the switch, but the problem persists. My wiring should be correct as it is plug-and-play with one extra output wire to the mirrors. Is there any combination of relays I can use to fix this problem? Thank you all in advance!
