12V thermostat reading 4 point temperature
Discussion in 'General Electronics Chat' started by dmachado, Apr 10, 2015.
  1. dmachado
    Feb 28, 2014
    17
    Hello, I want to use a 12v thermostat to control the cooling of my led setup, this is a 4 ft. aluminum setup with two heatsinks.
    The thermostat I want to use is a 12v single probe NTC 10K thermostat, so I thought about measuring the average temperature using a 4 probe setup, 2 series of 2 in parallel, this would result in an average reading of the 4 probes, am I right?
    Thank you.
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    Maybe, maybe not.
    If the temperatures are about the same within a few degrees it might work. With wider temperature differences the transfer characteristics (linear or non-linear) would not give a true average.
  3. dmachado
    Feb 28, 2014
    17
    Yes, the temperatures would be close between the 4 reading points, I'll give it a try, thanks.
