I have no idea... It was working fine. I guess it wasn't the one we were supposed to be using...it was an IRF640... I soldered a 1KΩ resistor on to the gate end and it did what it was supposed to. but with one difference, if I touched it to the positive the light came on and stayed on until I touched it to the neg. terminal. But then the light started to come on all by itself.Well, live and learn I guess. But how did you fry it? Did you forget the load, so that you shorted it when you turned it on? They are static-sensitive, but you need a lot of current to fry one UNLESS you had its gate held in between on and off, from 1-8 volts or so.
Since there is almost no current, a large resistor will work for low speed switching, and so will NO resistor. A very low resistance allows faster switching. Some resistance is usually added to damp LC ringing of the gate....so you can limit the gate current with a resistor like a 100, 000 ohm.
I'm sure he has some experience to refer to but you'll get a lot longer life out of a proper MOSFET circuit. They sit in your TV and switch hundreds of volts at high frequencies all day long for years.... but little relays are way more rugged.
Yup, a SSR is just like a relay, in the sense that you can use it to have a DC circuit control an AC circuit, but it is not a mechanical device.If you want AC control, then get some SSR (solid state relays)
That comment makes no sense to me. When on, the gate is at 10-15V and the drain is very nearly 0V, same as source. So the gate is above the drain frequently in normal operation. It's true that gate-to-source is usually max at 15V (per the datasheet), and you don't want to exceed that....dont let the gate terminal get higher than the drain terminal
[[[[That's my understanding of it, that each of 4 input types can produce a +12V signal into the controller that needs to be defined. The OP said he wants a toggle, so that a change in any of those 4 inputs should change the state of the load. I guess that includes going from +12 to zero, not just from zero to +12.I'm still unsure of what the OP actually needs?
Wayneh (or Zapstrap) are you saying there are 4 switches, and toggling any switch needs to produce the result of toggling the load on/off?
Excellent sir. Thank you.Hmm, ok so the idea is to make it so when ANY switch is changed, the output will toggle. That lets you turn the output on/off from any switch. Yes, that's the goal.
In a 2 switch system that can be done by 2 SPDT changeover switches, as done in 2 switch hallway lighting.
With more than 2 switches it can be done with a DPDT switch at every node, so each node basically reverses the two wires. The first and last switch can be SPDT types, all the middle switches need to be DPDT types. I have played with these 3 and 4 way switches in my AC power.
This will work fine but means of course the power must go in series through every switch. Since you are talking about high current DC power, I would send a low current control signal through the series switches, then use that signal to control the main power relay on/off. This is sounding promising!
Anyway that's a simple reliable solution, using a switch or relay for each node, and one large power relay at the end to switch the main load.
...If ignorance is bliss then I'm freeking ecstatic!...Hi again, if you have relays for each node, you can do the multi-master toggling the way I suggested using two SPDT relays for the first and last nodes, and DPDT relays for the nodes in the middle.
by Aaron Carman
by Duane Benson
by Aaron Carman
