12v speed control help
Discussion in 'The Projects Forum' started by AggieTX, Sep 29, 2010.
  1. AggieTX
    Sep 29, 2010
    Hopefully, you guys can help me.
    I'm using a car battery charger to power a windshield wiper motor. The motor is spinning a bicycle gear which is spinning a rotisserie.
    My problem is that under load, it spins too fast. Would a speed controller work? I can build circuits, but I'm not any good at designing them.
    Thanks for any help that can be provided.
  2. Pich
    Mar 11, 2008
    119
    search PWM circuit using a 556 timer lots around or motor speed control using PWM.
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    Actually just hooking a 12V lamp in series with the motor might work but we'd need to know how much current the motor draws.
  4. windoze killa
    Feb 23, 2006
    605
    24
    You could also try using different sized cogs on the motor.
  5. Bernard
    Aug 7, 2008
    4,235
    414
    Some possible bulbs, automotive types: 1129,1130, 6.4V,2.6A== 2.4Ω; 1133,1134, 6.2V, 3.91A =1.6Ω; 1143, 1144, 12.5V, 2A =6.25Ω;1156, 12.8V, 2.1A = 6.Ω
    If wider range of control is desired, try a darlington power transistor like D1326, NTE2336, TIP261. TIP263, configured as emitter follower, with 1k to 5k pot for control, heat sink needed.
