My apologies if there is another thread here that answers this however I need your help. I am trying to come up with a very basic circuit for a bank of 12vdc SLA batteries that will do a couple of task mentioned below.
1. Prevent deep cycling a battery - Automatically cuts off the battery from the reset of the circuit from being used if it reaches below X voltage. The trick here is that the batteries are in a series/parallel circuit. So I am thinking the only way to do this is to cut both batteries that are in series with each other if one (or both) drop below the set voltage.
2. Overcharging Protection - A circuit that automatically cuts the charge voltage (15v) from each 12v SLA battery once the battery has completely charged. Basically this would allow each battery to be charged independently which is the ONLY way you can ensure a complete charge and ensure it's not overcharged. The charger supply would be 15VDC.
This link is to an older thread on the subject but it seems incomplete.
http://forum.allaboutcircuits.com/threads/11v-14-8v-cutoff-circuit.59297/
This link is along the lines of item 2 above....I think it would work but with the introduction of item 1, I am not sure how to approach. Obviously the removal of the cap and rectifier would be done since it's not needed.
http://www.electronicshub.org/automatic-battery-charger-circuit/
Thanks for any advise in advance!
