12v sensor switch
Discussion in 'The Projects Forum' started by byronious, Jan 17, 2015.
  1. byronious
    Jan 17, 2015
    its a 12 volt DC sensor switch. There's three holes to insert wires into. one has an L. one has an N and o:..ne says load. I don't know what thismeans. can someone please explain this to me?
  2. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi,
    The letters L N and Load usually apply to mains wiring connections.?
    When you say 12V DC , is that the control voltage input.
    Post a part number or link.
    E
  3. byronious
    Jan 17, 2015
    this is an extremely very simple on off switch it came from overseas so there's not a part number that I can find. Its made for 12 volts for light LED lighting and what not.
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Generally a simple contact closure switch that is marked that way is one that has an internal on/off indicator light/led.
    If it is a solid state switch then the load terminal could be a NPN or PNP open collector.
    Max.
