12v Push button auto fading LED
Discussion in 'The Projects Forum' started by Pizzaguy321, Jun 7, 2013.
  1. Pizzaguy321
    Jun 7, 2013
    Hello all
    I am doing an LED project where I need the LEDs to turn on immediately when a button is pushed but as soon as the button is released it starts to slowly fade out. The fade out time needs to be adjustable because it is for a theater performance and may needs adjusting once used on stage. I am hoping to use about 25 1 watt LEDs. Any help is greatly appreciated because I don't know where to start, I read I could use a 555 mixed with capacitors and resistors but not sure if that's what I should do.
    Thanks!
    -Michael
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    Do you want one switch to control one LED or one switch controls all 25 LEDs?
    How long is "slowly", 1, 3, 10, 30 seconds (minutes?)?
  3. Pizzaguy321
    Jun 7, 2013
    I want the button to control all 25 LEDS, if i could have the fade be between 3 to 5 minutes that would be great!
    Thanks!
