12v priority switch?
Discussion in 'General Electronics Chat' started by caladina, Jun 16, 2009.
  1. caladina
    May 10, 2009
    9
    car lighting 12V,
    I have two led light cicuits in a clear lamp one is red, brake and the other is white, reverse
    There are two sets of brake lights on either side of the car,
    I want to have the reverse lights take priority over the brake lights
    on the inner pair only, keeping the outers standard brake for obvious reasons.
    as mentioned i previous posts i know nothing of eletronic switches etc
    for this i'm thinking i need some type of priority switch (correct name)?
    when the live is active for the reverse it should cancel the live for the brake if the brake is live at that time,
    can anyone suggest or show me a link to that type of switch for auto 12v
    also is there a flow chart / diagram of the switches paths
    thank you in advance
  2. DC_Kid
    Distinguished Member
    Feb 25, 2008
    640
    9
    using a combo of NPN and PNP transitors you could wire it so that when the reverse lights are on it will unbias the red led transistor.
  3. caladina
    May 10, 2009
    9
    thanks, i just had a thought after i posted it, i could use a headlamp relay, they have tiny solinoids in that operate breakers,
    i'm gonna sound like a right thicko if NPN and PNP transitors are exactly that !!?
