12v power supply
Discussion in 'The Projects Forum' started by sajelectric, Sep 22, 2011.
  1. sajelectric
    Aug 19, 2011
    15
    Hi, I am looking for a 12v 5a d.c power supply having 50ma output, to operate a relay coil and thus a 12v 5a motor. Please tell me where it is available and what is the cost? Or give me a circuit to make one.
  2. mcgyvr
    Oct 15, 2009
    4,793
    976
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Let's see, you want a 12v, 5A DC power supply that has a 50mA output?
    This doesn't seem to make sense. Do you mean that it needs to have something like a "voltage good" signal in order to operate the relay coil?
    It's not good to operate a supply at 100% capacity. You should use a supply rated for more than your load.
    Also, motors draw many times as much current when stalled (or starting from a stop) than they do when running at speed with no load. Is the 5A specification the stall current or the no-load current, or something else?
  4. mcgyvr
    Oct 15, 2009
    4,793
    976
    I thought he just wanted a power supply to use for powering both the relay and the motor..
    Just an 12V 8A or 10A or whatever power supply. (5A+50mA+safety factor)
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Possibly the cheapest way to get a supply would be to do the "ATX bench supply" modification on a computer supply that has a suitable 12v rating.
    But, we don't know where our original poster is, so suggesting a supplier would be pointless.
  6. sajelectric
    Aug 19, 2011
    15
    Its a small customized motor which draws a current 5A max.
    Also need to power a relay(load 50MA max.)
    Please suggest the best power supply can be used.
  7. mcgyvr
    Oct 15, 2009
    4,793
    976
    sajelectric likes this.
