Hello everyone
I am trying to build a simple 12V PIR switched light circuit to drive a pair of small 9W triple LED lights.
What I have a small SLA 12V 1.2Ah battery to which I am connecting my PIR.
For info here is a link to the PIR sensor I am using. It is cheap and cheerful but should still do the job?
I know, its a big link
http://www.aliexpress.com/item/NEW-...48&btsid=e1690b29-3164-4879-a113-7e8752fb30f2
The trouble is although it is working its not working correctly and wanted some input from shall we say more learned people.
The battery isn't fully charged but is charged enough showing a voltage of 12.15V. I have wired the + & - wires to the positive and negative posts on the battery as you would expect and am left with a single yellow output wire from the PIR. I'm sure the yellow wire is intended for connection to the negative wire on the led lights and as such have wired it that way with the red wire from the led lights going straight to the positive post on the battery.
Now the fun starts....
The sensor has a built in 15 second timer when activated but it seems to be half working and working in reverse. I'll explain.
With the wiring configured as above with the sensor unswitched I am getting a voltage of 12.04V across the light supply. If I wave my hand in the field of the sensor this reading drops to 8.82V. After 15 seconds the sensor unswitches and the reading goes back up to 12.04V.
So it seems to be working in reverse. Also, I would expect if working correctly the unswitched voltage should read Zero because as it stands, when all connected. The Light is brighter unswitched and gets dimmer when the PIR is activated????
Should this be working correctly as a stand alone device or does it require some kind of mini relay perhaps?
Many thanks, Chris
Many thanks, Chris
