~12v Optocoupler Driver
Discussion in 'General Electronics Chat' started by mikemania, Apr 13, 2009.
  1. mikemania
    Apr 13, 2009
    Hello people. i'm new to this forum and this is my first post :) I need to drive an optocoupler from my motorcycle's battery. Battery voltage is 12 to 14.4, depending on the engine revs. can i drive the optocoupler with this voltage? Or do i need to limit the voltage? The optocoupler's output will only light up a 3v LED. which optocoupler should i use? 4n25?
    Thank you :)
  2. italo
    Nov 20, 2005
    205
    the voltage is ok but you must limit the input current to a safe value no more then 10ma safety and the output also to no more then 20 ma asume 14.4v need Ω1.0k input output 560Ω add a diode to the input anode to gnd breakdown is only 2v and this is for a 2n24 2n25 maybe better but i have no spec for it.
    good luck
  3. bioukanon
    Jun 6, 2009
    Hello to all. I need a circuit with a optocouple to switch a relay. The input that I need is 12V and the relay is 12V too. I 'll like to use like a simple relay. Do you pls tell me what resistance must choose and what optocoupler is good to make this circuit. Thanks
  4. treitmey
    Jul 16, 2009
    Why are you using an opto-coupler? What are you trying to do?
