12V Motor / Solenoid Circuit
Discussion in 'The Projects Forum' started by kmatz, Mar 15, 2010.
  1. kmatz
    Mar 15, 2010
    Hi All,
    I'm new to the forum, but from reading through posts i can tell there is a lot of knowledge here.
    Pretty simple problem:
    School project, using a 12V battery to operate a small motor and a valve's solenoid. I think I've got the circuit, but am not positive... (see diagram).[​IMG]
    Does this make sense? Are there any other considerations i should add?
    Also trying to make a cheap battery charger for this... i have an ac-dc converter, and a cig lighter battery charger... will these do the trick?
    Thanks in advance for your advice.
  2. Bernard
    Aug 7, 2008
    4,240
    414
    Looks workable; R1~ 47 ohms @ 1/2 W, snubber in parallel with SOL1- 62 ohms ,1/2 W, in series with .1uF; maybe diode in parallel with CR1, cathode toward +.
    kmatz likes this.
  3. kmatz
    Mar 15, 2010
    Awesome, thanks for your help!
