I own an older boat with in inboard engine. It used a magneto charging setup on the harmonic balancer to develop 12vdc used throughout the boat. Originally, the design used a seriously heavy duty resistor and power transistor that 'clamped' the magneto output at 14v as the engine rpm increased. This unit was water cooled from the engine's coolant system and frequently failed by becoming an open circuit and allowing the voltage to rise to 40 or 50 volts! Most owners of these systems simply toss the whole charging system overboard and install a belt driven alternator.
I rather like the concept of magnets inside the harmonic balancer rotating to produce charge on the engine mounted stator. This takes up little valuable engine bay space and it appeals because of its design efficiency. The problem is how to regulate the center tapped AC stator coil? Unlike an alternator, the flux is developed by magnets so I can't control the field. A mosfet power transistor is one idea, but I'm not sure how to design a circuit such that the input can vary from 12 to 60vac while maintaining a steady 13.8vdc output all while being able to supply up to 40 or 50 amps into a changing load? This system must charge the battery--a group 31 size--and run onboard electronics--radio, lights, fans, etc safely. Ideas?
