12v LED tail lights on 24v system
Discussion in 'General Electronics Chat' started by Slimsound, Apr 2, 2014.
  1. Slimsound
    Apr 2, 2014
    5
    I am new to this, and so would like some advice.
    I am building a toy car for my son and using a 24volt mobility scooter motor and electronics to power it.
    I have some 12v LED tail lights and some 12v LED headlights to use on it, what do I need to put on line to make it all work?
    I do not know anymore about the LED lights unless someone can tell me how to work it out?
    Do I need a 12v regulator inline on both or just a resistor?
    Thanks in advance for all your help
  2. inwo
    Nov 7, 2013
    2,435
    315
    If it was me, and it was a "toy" car. No safety issues. I'd connect them in series across the 24 volts.
  3. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    My Aurora has DTRL's in series the same way!
    As inwo says and You just need a series resistor for the LED's.
    Max.
  4. Slimsound
    Apr 2, 2014
    5
    Thanks guys, please could you just elaborate on the series resistor? I am not an electronics trained person.
  5. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    Do you have any info on the LED's?
    If they state 12v they may already be conditioned for 12v.
    Max.
  6. crutschow
    Mar 14, 2008
    13,469
    3,356
    You need to know the current the LEDs take at 12V. Then you add a resistor in series with value R = 12V / Iled.
  7. #12
    Nov 30, 2010
    16,657
    7,300
    I'm afraid you have wandered off the idea from inwo. Two lights in series need no resistor if they were built for 12 volts each (with their own internal limiting resistor).
    ErnieM and inwo like this.
  8. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    More info on the LEDs would be a good idea.
    If they just have internal resistors then no problem shoving them in series for 24V, if they have internal switch mode regulators - they may not share equally.
  9. inwo
    Nov 7, 2013
    2,435
    315
    Op called them 12V lights. I'm pretty sure he could wire them to 12V
    It should be a small step to explain a series connection.
  10. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    Most automotive replacement from 12v incandescent to LED's require no resistor.
    Max.
  11. Slimsound
    Apr 2, 2014
    5
    Thanks everyone,
    This is the item number for the headlights I bought, 221360513476, it just says 12v but a guessing the will have all the correct resistors in them.
    The tail lights have got three resistors in them each so I thing I will just wire them in series.
    Many thanks
    Sorry for being dumb
  12. Ahmad Hassan_1450013929
    Dec 13, 2015
    it can be worked by the aid of the concept (Potential Divider )
    and its easy that you can do it by your self
    Just let us first say that have
    Vs (Voltage source) =24 volt
    V led(voltage for the LED you have)=12 v
    Solution..
    you need to introduce 2 resistance and the values for those resistance will be calculated by the following equation:
    V led = Vs*(R1/R1+R2)
    12 = 24*(R1/R1+R2)
    from solving the last equation we will found that R1 = R2
    So technically if add any two resistance in series equal each other (they can 1kohm 7 1Kohm or they can be less )
    and then you connect you LED in Series to any one of them you will have voltage on the resistance equal 12v and it the required voltage ;)
    Note : those resistance will added in series to each other and you lamp will be allocated in parallel to the R that gives you the required voltage drop.
  13. #12
    Nov 30, 2010
    16,657
    7,300
    The Thread Starter (Slimsound) was last logged in 20 months ago. He/she probably got the lights running, let the children wreck the toy car, and forgot about it. If you only answer recent questions, you are more likely to find an audience that still visits this site.
  14. ian field
    Oct 27, 2012
    4,447
    791
    Aliens watch all our communications.
