12V - Lead Battery - Datasheet reading
Discussion in 'Electronics Resources' started by Shah_Key, Apr 29, 2013.
  1. Shah_Key
    Jan 8, 2013
    23
    Hello
    I am trying to read a datasheet for a 12V lead battery but i dont understand one section
    Could you please explain what is meant by:
    (Please see image 1.jpg and 2.jpg )
    The data sheet is:
    View attachment 44240.pdf
    Thank you in advance
  2. ScottWang
    Aug 23, 2012
    4,934
    777
    VPC - Voltage Per Cell, Minimum allowable volts per cell.
    You can check the left side of the page 6 from this.
    Shah_Key likes this.
  3. Shah_Key
    Jan 8, 2013
    23
    Thank you ScottWang
    This might be a dumb question but...
    Can I use this information to tell me how long it would take to charge the battery?
  4. ScottWang
    Aug 23, 2012
    4,934
    777
    VPC is using to describe the numbers of battery, and the minimum allowable volts for each cell.
    For the Lead Battery charging time:
    When you first times to charge the battery, then you can using 0.1C or less to charge the battery.
    The normally charging time is 0.3C.
    C is the current of battery, assuming the current are 7A, exp : 7A*0.3 = 2.1A, it means that the Imax for charge current.
  5. Shah_Key
    Jan 8, 2013
    23
    ok I kind of understand you
    Im now stuck on trying to find out how long it would take to charge the battery.
    I have purchased the BEG120120 battery and I have a solar panel which I will be using to charge the battery. I am trying to work out how long it would take to fully charge the battery.
    Do you have any ideas on how i could go around this please?
