12v drop to 9v
Discussion in 'General Electronics Chat' started by Laserdog, Jun 30, 2008.
  1. Laserdog
    May 3, 2008
    5
    I have a purchased 9 volt rated timer circuit and would like to use it on my boat that has a 12 volt battery. Would rather use the 12v boat battery than purchase 9 volt batteries. Is there a divider circuit or some regulator circuit that could be easily built to provide the 9 volts from the 12 volt battery? If So could someone provide info.
  2. silvrstring
    Mar 27, 2008
    159
    Does your timer say how many Watts it uses?
  3. Laserdog
    May 3, 2008
    5
    It is an Adjustable Cyclical Timer . The only electrical
    Specifications:Supply voltage: 9V DC / 100mA
  4. silvrstring
    Mar 27, 2008
    159
    That means your timer uses .9 W of power (P=IV), and the resistance of your timer is about 90 ohms because R=(V^2)/P.
    If you place a 30 ohm resistor in series with the timer, your timer will get about the 9V that is recommended for it; the resistor will take the other 3V. Just make sure your resistance is rated about 2 times the power it will be dissipating. Your resistor would be using about .3 W of power, so make sure it is rated at or above about .75 W to be safe.
  5. silvrstring
    Mar 27, 2008
    159
    You could also use a zener diode in parallel with the timer, but resistors are easier to find.
  6. blocco a spirale
    Jun 18, 2008
    1,461
    370
    You should use one of these:
    http://www.fairchildsemi.com/pf/LM/LM7809.html
    The problem with using a resistor is that the voltage is entirely load dependent and if the current drawn by your timer changers then so will the voltage. Also, your boat battery is only nominally 12V and will be several volts higher when the engine is running.
  7. silvrstring
    Mar 27, 2008
    159
    Yes, the regulator would be best--especially considering a running engine.
  8. Laserdog
    May 3, 2008
    5
    Thanks to all for alternative solutions to my problem. I think I will
    go with the regulator :rolleyes:
