12v dc to 6v dc
Discussion in 'General Electronics Chat' started by PhiDor, Dec 24, 2010.
  1. PhiDor
    Dec 24, 2010
    I have restored a 1939 Farmall tractor. I have headlights for it, but no tail lights yet. There is no generator on this tractor. I have a 12v deep cycle battery I carry on my Airstream Tt for general use, not the system. This battery would be perfect to run the lights for a couple of hours tops, on a hayride or what have you. What can I buy, inexpensively, and VERY SIMPLE to hook up to use this battery. The lights are old also, using 6v sealed beams. I don't envision putting on a generator or anything permanent in the near future.
    Thanks and Merry Christmas.
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Voltage divider.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    I would connect the headlights in series, instead of parallel. Same goes for tail lights. That or buy a 6Vbattery.
    John
  4. shteii01
    Feb 19, 2010
    3,500
    511
    That is a good idea. The two lights in series would make natural voltage divider to split 12V into 6V and 6V. Very elegant.
  5. bassplayer142
    Jan 2, 2007
    89
    Ya, but two of them in series to get a 6V drop on each one. A voltage divider would work but they would need to be power resistors which is very wasteful if they are powering high power loads such as conventional light bulbs.
  6. marshallf3
    Jul 26, 2010
    2,358
    201
    6V batteries aren't too hard to find but it would be to your advantage to convert the bulbs to 12V (they're going to fail eventually) then rig one of the mid 1970s GM alternators up to the engine to keep it charged. It's a simple one-wire alternator as in the rectifier and regulator are built in and it only takes one wire to the battery, no switching as it only comes into play when it senses a load or if the battery needs charging.
    If you search around the antique tractor websites you'll find this to be the most popular option, just a matter of mounting and getting a V-belt over to it.
