12v DC to 12 AC
Discussion in 'The Projects Forum' started by tabeta_03, Mar 8, 2013.
  1. tabeta_03
    Mar 8, 2013
    I have a mini incubation at home that is working whit 12 volt AC - 1.5 amp and 10 watt.i am trying to turned it on with 12v DC -5amp dry-cell battery but i need a 12v DC to 12v AC inverter plz help me abut that.i need a circuit board map and requirement list to make it at home.I am not professional in electronics please give a full explanation on how to bilet the circuit.:(
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    Show us a photo or some specs on the incubator.
    If it is simply a resistive heater you can connect the 12V battery directly. But don't try it unless you are certain that this will work.
    tabeta_03 likes this.
  3. tabeta_03
    Mar 8, 2013
    heater&Fan&Gear
    Thermoregulator
    if i connect directly power to heater i can't control the temperature!
  4. tabeta_03
    Mar 8, 2013
    plz help meeee
  5. shortbus
    Sep 30, 2009
    4,095
    1,681
    What does does the label on the fan say? AC or DC?
  6. MrChips
    Oct 2, 2009
    12,633
    3,453
    Can you post a larger photo of the regulator so that we can read the part numbers on the board?
