12v DC switch in AC project
MaxHeadRoom
Joined Jul 18, 2013
28,702
Why not use the 120vac versions? They are the same configuration as the ones shown.
Do you need the same current rating as those?
Max.
asilvrhaze
Joined Mar 23, 2015
I'm going for a certain look, the toggle switch with flippable safety cover type, similar to what you would see in an aircraft cockpit.
mcgyvr
Joined Oct 15, 2009
5,394
The answer is absolutely not..
Components must be used within their ratings..
As stated there are plenty of AC rated "cockpit" style switches..
