12v circuit
Discussion in 'The Projects Forum' started by sajelectric, Jan 26, 2012.
  1. sajelectric
    Aug 19, 2011
    15
    The 12v circuit provided turn on by an open collector signal.
    Can somebody modify the circuit if I want to operate it with a toggle switch if the open collector signal pin is not activated?
    Please provide the circuit.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Connect a single-pole, single-throw switch from the OPEN COLLECTOR input to GND.
    That way either the open collector signal or the switch can turn on the fans.
    I can't draw you a schematic, as I'm on a WebTV type thing and have no drawing tools availabie.
  3. williamj
    Sep 3, 2009
    180
    32
    sajelectric,
    I believe this is what SgtWookie is talking about.
    williamj
